Ga door naar hoofdinhoud
Dell Inspiron 1410 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 1410 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Remove the two screws securing the hard drive assembly to the system board.
  2. Dell Inspiron 1410 Hard Drive Replacement, Removing the Hard Drive Assembly: stap 2, afbeelding 1 van 1
    • Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
  3. Dell Inspiron 1410 Hard Drive Replacement, Removing the Hard Drive Cage: stap 3, afbeelding 1 van 1
    • Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
  4. Dell Inspiron 1410 Hard Drive Replacement, Placing the Hard Drive: stap 4, afbeelding 1 van 1
    • Place the NEW hard drive in the hard drive cage and press it down until it snaps into place.
  5. Dell Inspiron 1410 Hard Drive Replacement, Aligning the Hard Drive: stap 5, afbeelding 1 van 1
    • Push down the hard drive assembly in place by aligning the hard drive connector with the system board connector.
  6. Dell Inspiron 1410 Hard Drive Replacement, Replace the Screws: stap 6, afbeelding 1 van 1
    • Replace the two screws securing the hard drive assembly to the system board.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 387
