Inleiding
The Thermal-Cooling Assembly is used to keep your laptop from overheating while running. If this breaks and is not replaced you run the risk of frying your motherboard.
Wat je nodig hebt
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Lift the coin cell battery wire, and carefully remove from motherboard.
Disconnect cables connected to the motherboard by lifting the flaps up and pulling out.
This is a ZIF connector and needs to have the side flaps flipped up before removal.
