Inleiding
The Cooling fan is used to remove heat from the laptop so it is not hot to the touch and does not burn the motherboard.
Wat je nodig hebt
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Één andere persoon heeft deze handleiding voltooid.
