Inleiding
The Coin-Cell Battery is a power source for the motherboard while the computer is off. It is used to keep track of the system clock.
Wat je nodig hebt
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Lift the coin cell battery wire, and carefully remove from motherboard.
Één andere persoon heeft deze handleiding voltooid.
