Ga door naar hoofdinhoud
Dell Inspiron 14-5447 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 14-5447 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 14-5447 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 14-5447 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 14-5447 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: stap 5, afbeelding 3 van 3
    • Locate the five small slits at the top of the keyboard.
    • Using a plastic opening tool, carefully pry each slit to loosen the keyboard.
    • Slide the keyboard towards the screen at an angle for removal.
    • Be cautious when lifting the keyboard because there are secured, fragile wires connected underneath it.
  6. Dell Inspiron 14-5447 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 14-5447 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • If the keyboard is not lifted with caution, damage to the cables may occur.
    • Lift the keyboard and flip it onto the mouse-pad.
  7. Dell Inspiron 14-5447 Keyboard Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 14-5447 Keyboard Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 14-5447 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Locate the two cable connectors. These connectors secure the cables to the laptop with small, securing flaps.
    • To release the cables, take each flap and flip them upwards to the unlocking position.
    • Pull both the cables out after unlocking and set aside the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 1,336
