Ga door naar hoofdinhoud
Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement
Wat je nodig hebt
  1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): stap 2, afbeelding 1 van 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: stap 3, afbeelding 1 van 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: stap 4, afbeelding 1 van 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: stap 5, afbeelding 1 van 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
Conclusie
Alec Siegel
598 Reputatie
4 handleidingen geschreven
Baylor, Team S2-G2, Johnson Spring 2018 Lid van Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 803
