Ga door naar hoofdinhoud
Dell Inspiron 14 N4050 Battery Replacement
  1. Dell Inspiron 14 N4050 Battery Replacement, Turn off the Computer: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Dell Inspiron 14 N4050 Battery Replacement, Slide the Battery Latch: stap 2, afbeelding 1 van 1
    • Slide the battery lock latch to the unlock position until it clicks into place.
  3. Dell Inspiron 14 N4050 Battery Replacement, Sliding the Release Latch: stap 3, afbeelding 1 van 1
    • Slide and hold the battery release latch in the unlock position.
  4. Dell Inspiron 14 N4050 Battery Replacement, Lifting the Battery: stap 4, afbeelding 1 van 1
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron 14 N4050 Battery Replacement, Sliding the New Battery: stap 5, afbeelding 1 van 1
    • Slide the NEW battery into the battery bay until it clicks into place.
  6. Dell Inspiron 14 N4050 Battery Replacement, Sliding the Lock Latch: stap 6, afbeelding 1 van 1
    • Slide the battery lock latch to the lock position.
Eindstreep
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 341
