Ga door naar hoofdinhoud
Dell Inspiron 14 N4030 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 14 N4030 Display Assembly Replacement, Disconnecting the Display Cable: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 N4030 Display Assembly Replacement, Remove the Screws: stap 2, afbeelding 1 van 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 14 N4030 Display Assembly Replacement, Removing the Display Assembly: stap 3, afbeelding 1 van 1
    • Lift and remove the display assembly out of the computer base.
  4. Dell Inspiron 14 N4030 Display Assembly Replacement, Placing the Display Assembly: stap 4, afbeelding 1 van 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 14 N4030 Display Assembly Replacement, Connecting the Display Cable: stap 5, afbeelding 1 van 1
    • Connect the display cable to the connector on the system board.
Eindstreep
Terrence15
79.585 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 651
