Inleiding
In this guide, we will be showing you how to remove and replace the Display Assembly.
Wat je nodig hebt
Remove the two screws that secure the display assembly to the computer base.
Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
Lift and remove the display assembly out of the computer base.
Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables and display cable through the routing guides.
Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
Replace the two screws that secure the display assembly to the computer base.
