Ga door naar hoofdinhoud
Dell Inspiron 14 Gaming 7467 Memory Modules Replacement
  1. Dell Inspiron 14 Gaming 7467 Memory Modules Replacement, Removing the Memory Module: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 14 Gaming 7467 Memory Modules Replacement, Remove the Memory Module: stap 2, afbeelding 1 van 1
    • Remove the memory module from the memory-module slot.
  3. Dell Inspiron 14 Gaming 7467 Memory Modules Replacement, Align the Notch: stap 3, afbeelding 1 van 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
  4. Dell Inspiron 14 Gaming 7467 Memory Modules Replacement, Installing the Memory Module: stap 4, afbeelding 1 van 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 69
