Ga door naar hoofdinhoud
Dell Inspiron 14 Gaming 7467 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Camera Cable: stap 1, afbeelding 1 van 1
  2. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peel the Camera Cable: stap 2, afbeelding 1 van 1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screw: stap 3, afbeelding 1 van 1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  4. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Removing the Cable Bracket: stap 4, afbeelding 1 van 1
    • Lift the display-cable bracket off the system board.
  5. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Display Cable: stap 5, afbeelding 1 van 1
    • Using the pull-tab, disconnect the display cable from the system board.
  6. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peeling the Display Cable: stap 6, afbeelding 1 van 1
    • Peel off the display cable from the computer base.
  7. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: stap 7, afbeelding 1 van 1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  8. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: stap 8, afbeelding 1 van 1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: stap 9, afbeelding 1 van 1
    • Turn the computer over and open the display.
  10. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Lift the Display Assembly: stap 10, afbeelding 1 van 1
    • Lift the display assembly off the computer base.
  11. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: stap 11, afbeelding 1 van 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  12. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: stap 12, afbeelding 1 van 1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  13. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: stap 13, afbeelding 1 van 1
    • Close the display and turn the computer over.
  14. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: stap 14, afbeelding 1 van 1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Adhere the Cable: stap 15, afbeelding 1 van 1
    • Adhere the display cable and the camera cable to the computer base.
  16. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Route the Cables: stap 16, afbeelding 1 van 1
    • Route the antenna cables through the routing guides on the computer base.
  17. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Connect the Cable: stap 17, afbeelding 1 van 1
    • Connect the display cable and camera cable to the system board.
  18. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: stap 18, afbeelding 1 van 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  19. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screw: stap 19, afbeelding 1 van 1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Eindstreep
Terrence15
79.555 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 84
