Inleiding
In this guide, we will show you how to remove and replace the Memory Modules.
Wat je nodig hebt
Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
