Ga door naar hoofdinhoud
Dell Inspiron 14 5100 Motherboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: stap 1, afbeelding 1 van 3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: stap 1, afbeelding 2 van 3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: stap 1, afbeelding 3 van 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Motherboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Motherboard Replacement, RAM: stap 3, afbeelding 1 van 1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 Motherboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
  6. Dell Inspiron 14 5100 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Detach the white connector from the motherboard using the spudger.
  7. Dell Inspiron 14 5100 Motherboard Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Flip up the retaining flap and remove the blue ribbon cable from its connector on the motherboard using a spudger.
  8. Dell Inspiron 14 5100 Motherboard Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Flip up the retaining flap and remove the orange ribbon cable from its connector on the motherboard using a spudger.
  9. Dell Inspiron 14 5100 Motherboard Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Detach the CMOS battery connector using the spudger.
  10. Dell Inspiron 14 5100 Motherboard Replacement: stap 10, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the black connector using the spudger.
  11. Dell Inspiron 14 5100 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the single 3 mm screw from the Wi-Fi card using the Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of the slot and set aside.
  12. Dell Inspiron 14 5100 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the single screw from the SSD using the Phillips #0 screwdriver.
    • Remove the SSD from the motherboard.
  13. Dell Inspiron 14 5100 Motherboard Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove two 2 mm screws using the Phillips #0 screwdriver.
  14. Dell Inspiron 14 5100 Motherboard Replacement: stap 14, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Disconnect the cable from its connector on the motherboard using the spudger.
  15. Dell Inspiron 14 5100 Motherboard Replacement: stap 15, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Lift the metal retaining flap using the opening tool.
    • Remove the connector from the bracket.
  16. Dell Inspiron 14 5100 Motherboard Replacement: stap 16, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Detach the cable using the spudger.
  17. Dell Inspiron 14 5100 Motherboard Replacement: stap 17, afbeelding 1 van 2 Dell Inspiron 14 5100 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Detach the connector using the spudger.
  18. Dell Inspiron 14 5100 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Remove six 3 mm screws using the Phillips #0 screwdriver.
  19. Dell Inspiron 14 5100 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Remove the motherboard by lifting it from the rear and then completely removing it from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 673
