Inleiding
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
Wat je nodig hebt
Remove the four screws that secure the hard-drive assembly to the computer base.
Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Pull the interposer to disconnect it from the hard drive.
Replace the four screws the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the computer base.
Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
Replace the four screws that secure the hard-drive assembly to the computer base.
Één andere persoon heeft deze handleiding voltooid.
