Inleiding
In this guide, we will show you how to remove and replace the Memory Module.
Close the display and turn the computer over.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
