Ga door naar hoofdinhoud
Dell Inspiron 13z 5323 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • First flip the device over, so the bottom is facing you. Then you will remove the highlighted screw.
  2. Dell Inspiron 13z 5323 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 13z 5323 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 13z 5323 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Flip over the laptop and open it so that the screen is facing you.
    • At the top side of the Keyboard closest to the screen you will find 2 inset plastic clips. The clips are shown here in red. Using the flat and of the metal prying tool bend the clips in and at the same time lift the keyboard up.
    • Their is a ribbon connector still attached to the bottom of the keyboard. You should be careful not to damage this cable.
  3. Dell Inspiron 13z 5323 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 13z 5323 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • The ribbon connector seen in yellow can be removed by flipping up the plastic hinge clamp with a thin plastic pry lever
Conclusie
Chase Hussey
201 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G6
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 367
