Ga door naar hoofdinhoud
Dell Inspiron 13z 5323 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 2, afbeelding 3 van 3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 13z 5323 Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Conclusie
Chase Hussey
201 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G6, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G6
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 876
