Inleiding
This guide will assist in replacing the speakers on a Dell Inspiron 13-7373. This is not very difficult and requires very little removal of other parts of the laptop. You will need a screwdriver along with a tool to open the laptop.
Wat je nodig hebt
Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
Use an opening tool to remove the bottom half of the case from the laptop.
Unplug the connector from the motherboard on the right side of the speaker.
Één andere persoon heeft deze handleiding voltooid.
