Ga door naar hoofdinhoud
Dell Inspiron 13-7373 Motherboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: stap 2, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 13-7373 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 13-7373 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: stap 5, afbeelding 1 van 1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: stap 7, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: stap 8, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: stap 11, afbeelding 1 van 3 Dell Inspiron 13-7373 Motherboard Replacement: stap 11, afbeelding 2 van 3 Dell Inspiron 13-7373 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Gently lift up on the motherboard to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Egan
461 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 1,260
