Ga door naar hoofdinhoud
Dell Inspiron 13-7359 Speaker Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: stap 2, afbeelding 1 van 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 13-7359 Speaker Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 13-7359 Speaker Replacement: stap 3, afbeelding 3 van 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 13-7359 Speaker Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 13-7359 Speaker Replacement: stap 4, afbeelding 3 van 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Dell Inspiron 13-7359 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 13-7359 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 13-7359 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Katie Ragsdale
192 Reputatie
1 Handleiding geschreven
Baylor, Team S1-G6, Johnson Spring 2018 Lid van Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 362
