Ga door naar hoofdinhoud
Dell Inspiron 13-7359 Cooling Fan Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: stap 3, afbeelding 1 van 2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: stap 3, afbeelding 2 van 2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
Conclusie
Valentin Medina
697 Reputatie
3 handleidingen geschreven
Baylor, Team S1-G6, Johnson Spring 2018 Lid van Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 658
