Ga door naar hoofdinhoud
Dell Inspiron 13-7359 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: stap 2, afbeelding 1 van 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 13-7359 Battery Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 13-7359 Battery Replacement: stap 3, afbeelding 3 van 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 13-7359 Battery Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 13-7359 Battery Replacement: stap 4, afbeelding 3 van 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Conclusie
4 andere personen hebben deze handleiding voltooid.
Valentin Medina
697 Reputatie
3 handleidingen geschreven
Baylor, Team S1-G6, Johnson Spring 2018 Lid van Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Leden
5 handleidingen geschreven
Één opmerking
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,593
