Ga door naar hoofdinhoud
Dell Inspiron 13-7353 Motherboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 13-7353 Motherboard Replacement, Flip the Computer: stap 1, afbeelding 1 van 1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Motherboard Replacement, Secure the Base: stap 2, afbeelding 1 van 1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Motherboard Replacement, Pry the Base cover: stap 3, afbeelding 1 van 1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Motherboard Replacement, RAM: stap 4, afbeelding 1 van 2 Dell Inspiron 13-7353 Motherboard Replacement, RAM: stap 4, afbeelding 2 van 2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Motherboard Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 13-7353 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Motherboard Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Motherboard Replacement, Fan: stap 7, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Fan: stap 7, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Fan: stap 7, afbeelding 3 van 3
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Motherboard Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 13-7353 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: stap 9, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: stap 9, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Heat Sink: stap 9, afbeelding 3 van 3
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: stap 10, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Remove 2 M2 3mm bracket screws, using the Phillips 1 screwdriver, on the LCD cable bracket.
    • Remove the bracket on the LCD cable.
  11. Dell Inspiron 13-7353 Motherboard Replacement: stap 11, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 11, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the plug of the LCD cable.
    • Remove the plug of the touchscreen cable.
  12. Dell Inspiron 13-7353 Motherboard Replacement: stap 12, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 12, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Remove the plug of the DC Jack cable.
    • Remove the plug of the speaker cable.
  13. Dell Inspiron 13-7353 Motherboard Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 13-7353 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Be gentle and slow when loosening the keyboard cable tape.
    • Loosen the top of the keyboard tape.
    • Loosen the latches of the keyboard cable with a screwdriver.
    • Remove the plug of the keyboard cable.
  14. Dell Inspiron 13-7353 Motherboard Replacement: stap 14, afbeelding 1 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 14, afbeelding 2 van 3 Dell Inspiron 13-7353 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Remove the plug of the touchpad cable.
    • Remove the plug of the keyboard backlight cable.
  15. Dell Inspiron 13-7353 Motherboard Replacement: stap 15, afbeelding 1 van 2 Dell Inspiron 13-7353 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Remove one M2 2mm wafer screw, using the Phillips 1 screwdriver, from the motherboard.
    • Remove the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 953
