Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The device battery provides the main source of power, and must be removed to perform most other repairs on the device.
  1. Before disassembling your laptop, be sure it is powered off. Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head Use the plastic opening tool to remove the back panel.
    • Before disassembling your laptop, be sure it is powered off.
    • Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
    • Use the plastic opening tool to remove the back panel.
  2. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  3. Remove the two 3mm screws with the Phillips #0 head that  hold down the battery. Remove the Hard Drive wire from the battery clip by detaching the wire
    • Remove the two 3mm screws with the Phillips #0 head that hold down the battery.
    • Remove the Hard Drive wire from the battery clip by detaching the wire
  4. Gently remove the battery from the rest of the device.
    • Gently remove the battery from the rest of the device.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Mikinna Martin
428 Reputatie
2 handleidingen geschreven
Last I looked up for a different model there was a video..
pc2053 - Antwoord
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Antwoord
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 53
Afgelopen 30 dagen: 299
Altijd: 22,025
