Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
Remove the 1.5mm Phillips #0 screws that hold the touchpad to the laptop case.
Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
