Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
Disconnect the cable connecting the battery to the motherboard, and then remove the battery.
Using the Phillips #0 screwdriver, unscrew the 4 heatsink screws.
Remove the heatsink assembly.
Using the Phillips #0, unscrew two 3mm screws holding the fan in place and disconnect the cable connecting it to the motherboard. There is an adhesive tab holding the hard drive cable in place up against the fan; remove this as well.
Disconnect the following cables that connect to the motherboard: the Touchscreen, Display, and the speaker cable.
Disconnect the following cables that connect to the motherboard: hard drive cable and touchpad cable.
Using the Phillips #0 screwdriver, remove the three 2mm screws holding the motherboard in place. Once done, carefully lift the motherboard out.
Flip the motherboard over and, using a soldering iron, apply heat to the 7 solder points of the audio jack. Carefully pull the audio jack out from below.
