Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Is your computer not playing music from your headphones? Consider using this guide to replace the audio jack in your laptop. You’ll need to know how to solder to completely remove the audio jack. For more information on soldering, use the How to Solder and Desolder Connections guide.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
