Ga door naar hoofdinhoud
Dell Inspiron 13 N3010 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Turn the computer over.
    • Slide the battery lock latch to the unlock position.
  2. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Release Latch: stap 2, afbeelding 1 van 1
    • Slide the battery release latch to the side.
  3. Dell Inspiron 13 N3010 Battery Replacement, Lifting the Battery: stap 3, afbeelding 1 van 1
    • Slide and lift the battery out of the battery bay.
  4. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery: stap 4, afbeelding 1 van 1
    • Slide the NEW battery into the battery bay, until it clicks into place.
  5. Dell Inspiron 13 N3010 Battery Replacement, Sliding the Battery Lock Latch: stap 5, afbeelding 1 van 1
    • Slide the battery lock latch to the lock position.
Conclusie
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 177
