Inleiding
Many users of the Dell Inspiron 13 7378 complain about its slow processing speed. One way to increase processing speed is adding more RAM. This guide will show you exactly how to do that. The RAM compartment in this device has two slots. When you purchase your device, it comes with one slot full and one slot empty. Following this guide will allow you to either replace your existing stick, or add a second one.
Wat je nodig hebt
To remove a RAM stick, gently pull apart the metal tabs on either side of the stick.
Carefully grasp the stick on its side and pull it out.
Één andere persoon heeft deze handleiding voltooid.
