Inleiding
If you're experiencing overheating issues with your Dell Inspiron 13 7378, a quick and effective solution is to replace the fan. In this fast-fix, we'll guide you through the process of safely and efficiently replacing the fan in your laptop, helping to restore optimal cooling performance and prevent potential damage to your device. Let's get started!
Wat je nodig hebt
Remove the two 3 mm screws holding the fan in place using a Phillips screwdriver.
Replace the back cover to complete the process.
