Ga door naar hoofdinhoud
Dell Inspiron 11z-1121 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: stap 2, afbeelding 1 van 2 Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: stap 2, afbeelding 2 van 2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 11z-1121 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 11z-1121 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
    • To be safe, make sure you either wear an anti-static wrist band, or rub your hands against a metal object to remove any static.
Conclusie
Brandan Eng
143 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-5, Nance Fall 2016 Lid van USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 1,983
