Ga door naar hoofdinhoud
Dell Inspiron 11z 1120 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 11z 1120 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 11z 1120 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: stap 2, afbeelding 1 van 2 Dell Inspiron 11z 1120 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: stap 2, afbeelding 2 van 2
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 11z 1120 Hard Drive Replacement, Lifting the Hard-Drive Assembly: stap 3, afbeelding 1 van 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 11z 1120 Hard Drive Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 11z 1120 Hard Drive Replacement, Lifting the Hard-Drive: stap 5, afbeelding 1 van 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 11z 1120 Hard Drive Replacement, Placing the Hard Drive: stap 6, afbeelding 1 van 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 11z 1120 Hard Drive Replacement, Replace the Screws: stap 7, afbeelding 1 van 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 11z 1120 Hard Drive Replacement, Placing the Hard-Drive Assembly: stap 8, afbeelding 1 van 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 11z 1120 Hard Drive Replacement, Sliding the Hard-Drive: stap 9, afbeelding 1 van 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 11z 1120 Hard Drive Replacement, Replace the Screws: stap 10, afbeelding 1 van 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Conclusie
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 196
