Ga door naar hoofdinhoud
Dell Inspiron 1100 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 1 van 2 Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 2 van 2
    • Unscrew the one Phillips #0 screw at the bottom of the panel and remove the panel.
    • The screw does not separate from the cover. Be sure the screw is completely unscrewed before using force to remove the cover.
  2. Dell Inspiron 1100 Wireless Card Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 1100 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the two 3mm Phillips #0 screws located on the card.
    • Be careful, as these screws are easy to strip.
  3. Dell Inspiron 1100 Wireless Card Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 1100 Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • Pull the white plastic tab on top of the card straight up to remove the card.
    • This step requires some light force. Be sure the screws from the previous step have been removed.
  4. Dell Inspiron 1100 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Use blunt nose tweezers to remove the power cable from the wireless card.
    • Make sure the tweezers are only gripping the head of the power cable and not any part of the wireless card, as this may damage the card.
Conclusie
Alexander Pacheco
610 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 Leden
9 handleidingen geschreven
2 opmerkingen
I believe that is a phone modem, not a wireless card. Might be wrong though.
George A. - Antwoord
i think your right as dell 1100 dont have a wifi slot only can use usb or pcmcia card
Conner Peden - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 624
