Ga door naar hoofdinhoud
Dell Inspiron 1100 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
    • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
    • This step does require some force. Be careful to not bend or break the plastic face plate.
  2. Dell Inspiron 1100 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 1100 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws securing the keyboard.
  3. Dell Inspiron 1100 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Lift up the keyboard to expose the ribbon header on the motherboard.
    • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
  4. Dell Inspiron 1100 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 1100 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
    • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
Conclusie
Alexander Pacheco
610 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 443
