Wat je nodig hebt
Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
Use your screw driver to remove the plastic cover in the center of the laptop.
Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
Bijna klaar!
Conclusie
