Ga door naar hoofdinhoud
Dell Inspiron 11-3164 Speaker Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: stap 1, afbeelding 2 van 2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: stap 2, afbeelding 2 van 2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Conclusie
Michael Kendziora
781 Reputatie
5 handleidingen geschreven
USF Tampa, Team S6-G4, Eyestone Spring 2018 Lid van USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 149
