Ga door naar hoofdinhoud
Dell Inspiron 11-3164 Screen Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3164 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
Conclusie
Michael Kendziora
781 Reputatie
5 handleidingen geschreven
USF Tampa, Team S6-G4, Eyestone Spring 2018 Lid van USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 159
