Ga door naar hoofdinhoud
Dell Inspiron 11-3162 Motherboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement, Back Cover Removal: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Motherboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Motherboard Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Motherboard Replacement, Battery: stap 5, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Motherboard Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: stap 7, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement, Wireless WLAN Card: stap 7, afbeelding 2 van 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Motherboard Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Use the tweezers to unplug the DC Jack.
  11. Dell Inspiron 11-3162 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Use the tweezers unplug the Speaker Cable.
  12. Dell Inspiron 11-3162 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Use the tweezers to remove the CMOS Cable.
  13. Dell Inspiron 11-3162 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use the tweezers to remove the Touchpad Cable.
  14. Dell Inspiron 11-3162 Motherboard Replacement: stap 14, afbeelding 1 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 14, afbeelding 2 van 3 Dell Inspiron 11-3162 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
  15. Dell Inspiron 11-3162 Motherboard Replacement: stap 15, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
  16. Dell Inspiron 11-3162 Motherboard Replacement: stap 16, afbeelding 1 van 2 Dell Inspiron 11-3162 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Remove the keyboard cable.
  17. Dell Inspiron 11-3162 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the motherboard by gently lifting upwards from the edges.
Conclusie
5 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 2,023
