Inleiding
This guide will tell you how to replace your LCD screen. When working with screens, be careful about electrical discharges, and take steps to assure that the battery is disconnected for awhile before you follow this guide.
Onderdelen
Geen onderdelen opgegeven.
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
4 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
