Ga door naar hoofdinhoud
Dell Inspiron 11-3162 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3162 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  2. Dell Inspiron 11-3162 Hard Drive Replacement, Slide and Lift the Hard-Drive: stap 2, afbeelding 1 van 2 Dell Inspiron 11-3162 Hard Drive Replacement, Slide and Lift the Hard-Drive: stap 2, afbeelding 2 van 2
    • Slide and lift the hard-drive assembly off the palm rest and keyboard assembly.
  3. Dell Inspiron 11-3162 Hard Drive Replacement, Remove the Screws: stap 3, afbeelding 1 van 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 11-3162 Hard Drive Replacement, Lifting the Hard Drive: stap 4, afbeelding 1 van 2 Dell Inspiron 11-3162 Hard Drive Replacement, Lifting the Hard Drive: stap 4, afbeelding 2 van 2
    • Lift the hard drive from the hard-drive bracket.
  5. Dell Inspiron 11-3162 Hard Drive Replacement, Align the Screw Holes: stap 5, afbeelding 1 van 1
    • Align the screw holes on the hard drive with the screw holes on the hard-drive bracket.
  6. Dell Inspiron 11-3162 Hard Drive Replacement, Replace the Screws: stap 6, afbeelding 1 van 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 11-3162 Hard Drive Replacement, Connecting the Hard Drive: stap 7, afbeelding 1 van 1
    • Slide and connect the hard-drive assembly to the connector on the system board.
  8. Dell Inspiron 11-3162 Hard Drive Replacement, Align the Screw Holes: stap 8, afbeelding 1 van 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly
  9. Dell Inspiron 11-3162 Hard Drive Replacement, Replace the Screws: stap 9, afbeelding 1 van 1
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Terrence15
79.161 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.986 handleidingen geschreven
Één opmerking
Can we replace the harddisk with SSD. Will that increase the performance of the laptop?
Winada Effendi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 34
Altijd: 6,005
