Ga door naar hoofdinhoud
Inleiding
In this guide, we will show you how to remove and replace the Display Assembly.
Onderdelen
Geen onderdelen opgegeven.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer.After working inside your computer, follow the instructions in After working inside your computer.
  2. Slide and lift the display-cable bracket off the system board.
    • Slide and lift the display-cable bracket off the system board.
  3. Open the latch and disconnect the display cable from the system board. Open the latch and disconnect the display cable from the system board.
    • Open the latch and disconnect the display cable from the system board.
  4. Open the palm rest and keyboard assembly at an angle.
    • Open the palm rest and keyboard assembly at an angle.
  5. Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  6. Slide and lift the palm rest and keyboard assembly off the display assembly.
    • Slide and lift the palm rest and keyboard assembly off the display assembly.
  7. Place the NEW display assembly on a flat and clean surface.
    • Place the NEW display assembly on a flat and clean surface.
  8. Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
  10. Slide the display cable into the connector on the system board and close the latch to secure the cable.
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  11. Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
    • Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
  12. Align the screw hole on the display-cable bracket with the screw hole on the system board.
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  13. Replace the screw that secures the display-cable bracket to the system board.
    • Replace the screw that secures the display-cable bracket to the system board.
Conclusie
Terrence15
78.197 Reputatie
441 handleidingen geschreven
Informative Technologies Inc. Lid van Informative Technologies Inc.
Community
38 Leden
1.960 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 393
