Ga door naar hoofdinhoud
Dell Inspiron 11-3152 Cooling Fan Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3152 Cooling Fan Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3152 Cooling Fan Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 11-3152 Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Cooling Fan Replacement, Battery: stap 4, afbeelding 1 van 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 11-3152 Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 Cooling Fan Replacement, Cooling Fan: stap 8, afbeelding 1 van 1
    • Locate the cooling fan.
    • The cooling fan is the curved metal piece in the top center of the laptop, opposite the battery.
  9. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 9, afbeelding 1 van 1
    • Using your fingernail, unplug the white power cable connector to the right of the cooling fan by pushing it away from the port.
  10. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the four 3mm screws using a Phillips #0 head.
  11. Dell Inspiron 11-3152 Cooling Fan Replacement: stap 11, afbeelding 1 van 1
    • Gently remove the fan.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hannah Benedict
182 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-6, Catania Spring 2016 Lid van UMass Dartmouth, Team 4-6, Catania Spring 2016
UMASSD-CATANIA-S16S4G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 285
