Inleiding
In this guide, you will be replacing the battery to your Dell Inspiron. When finished, you should understand how to dissemble the back panel and remove the battery.
Wat je nodig hebt
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Één andere persoon heeft deze handleiding voltooid.
