Ga door naar hoofdinhoud
Dell Inspiron 11-3147 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 2 van 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudgercan be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 3mm screw holding down the hardware using a plastic Philips Head #0 Screw Driver.
  3. Dell Inspiron 11-3147 Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Detach the wires connected to the wireless card.
  4. Dell Inspiron 11-3147 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Ensure both wires are detached from the piece.
  5. Dell Inspiron 11-3147 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Lift the wireless card upwards and remove.
Conclusie
William Brum
737 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 1,293
