Ga door naar hoofdinhoud
Dell Inspiron 11-3147 Replace the Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: stap 2, afbeelding 1 van 1
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
Conclusie
3 andere personen hebben deze handleiding voltooid.
William Brum
737 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 2,492
