Ga door naar hoofdinhoud
Dell Inspiron 11-3147 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3147 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 11-3147 RAM Replacement: stap 2, afbeelding 2 van 2
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
Conclusie
4 andere personen hebben deze handleiding voltooid.
William Brum
737 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 1,275
