Ga door naar hoofdinhoud
Dell Inspiron 11-3147 CMOS Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 2 van 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the CMOS Battery
Conclusie
William Brum
737 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 39
Altijd: 3,054
