Ga door naar hoofdinhoud
Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement
Wat je nodig hebt
  1. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement, Processor Fan and Heat Sink: stap 1, afbeelding 1 van 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
  8. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 8, afbeelding 1 van 1
    • Use a screwdriver to remove the two 2.3mm PH00 screws on the processor fan.
  9. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Use a PH0 screwdriver to loosen the 4 captured screws on the heat sink assembly.
  10. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Remove the processor fan and heat sink assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Muhammad Erchid
1.069 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G6, Leahy Fall 2018 Lid van USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 279
