Ga door naar hoofdinhoud
Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement
Wat je nodig hebt
  1. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement, Power Buttons and Volume-Buttons Board: stap 1, afbeelding 1 van 1
    • Close the computer and turn it over so that the bottom of the computer is facing up.
  2. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 7.6mm PH0 screws on the back cover.
  3. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to remove the cover from the back of the computer.
  4. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the three small 4.7mm PH0 screws that secure the battery.
  5. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 5, afbeelding 1 van 1
    • Move the hard drive cable away from the battery.
    • You want to make enough clearance to remove the battery without it catching on the hard drive cable.
  6. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery up and toward yourself to remove it, revealing the back of the keyboard underneath.
  7. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the cable for the power and volume buttons from the motherboard.
    • You may need to use a spudger to remove the cable from the routing guides by the speaker.
Conclusie
Muhammad Erchid
1.051 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G6, Leahy Fall 2018 Lid van USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 372
