Ga door naar hoofdinhoud
Dell Inspiron 11 i3147 Camera Replacement
Wat je nodig hebt
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: stap 7, afbeelding 1 van 1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: stap 8, afbeelding 1 van 1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: stap 9, afbeelding 1 van 1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: stap 10, afbeelding 1 van 1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: stap 11, afbeelding 1 van 1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: stap 12, afbeelding 1 van 1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 11 i3147 Camera Replacement: stap 13, afbeelding 2 van 2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: stap 15, afbeelding 1 van 1
    • Use a plastic opening tool to take the camera module off the display.
Conclusie
Muhammad Erchid
1.069 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G6, Leahy Fall 2018 Lid van USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 223
